Freeview - best aerial ?
Discussion in 'Freeview & YouView' started by jimbowley, Oct 26, 2004.
  1. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    I need a new aerial direction for freeview. My house is tall and higher than the houses it needs to point over, so I was thinking I could get the biggest aerial available and put it in the loft?
    Any thoughts?
  2. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    If you're in a good freeview area you're probably ok with this. Short of getting an aerial installer to check, the only way to be sure is to try it.
