Freeview,BBC Channels Not Working,Nokia 221T
Discussion in 'Freeview & YouView' started by Aletank, Aug 13, 2004.
  1. Aletank
    Aletank
    Aug 3, 2004
    84
    11
    Liverpool,UK
    I have the Nokia 221T freeview receiver, Its always worked great, was working great 2pm today.
    Now I can't get any BBC Channels, all the rest are fine. :confused: OK just tried BBC and they all working, Now ITV/Channel 4 aren't ? :(
    The left light is green the right is red, thats on the channels that don't work, The working channels have 2 green lights.
    Never had this problem before, Might the weather have something to do with it ??
    EDIT - My Signal Strength Meter is all the way down :confused:
    All my cables are connected fine etc, Nothings changed, Not as if i've been messing around the back of the TV etc
  2. peahead
    peahead
    Dec 14, 2002
    2,997
    St.helens
    +384
    your not the only one mate :laugh:
  3. Philly112
    Philly112
    Oct 17, 2003
    4,321
    Frodsham
    +1,670
    Well bugger me, it's not just my unit!
    Exactly same problem, 1st the BBC went, then ITV and Channel 5.
    Try reinstalling the channels. I did this once, and it couldn't pick up ITV at all. Did it a second time and they're all back.
    On second thoughts, maybe having ITV and Channel 5 missing is no big deal...
