Freeview And Top Up Tv
Discussion in 'Freeview & YouView' started by E Thomson, Jul 26, 2005.
  1. E Thomson
    E Thomson
    Jul 22, 2005
    94
    My mum and dad have a freeview box which does not have a card slot for top up tv. After seeing the channels I receive with top up they would like to be able to get it. They are wondering if they can get something that will enable them to get top up tv with the box they have at the moment or will they have to buy a new freeview box which has top up tv. Would appreciate any help you can give.
  2. GaryB
    GaryB
    Nov 12, 2002
    5,381
    St Albans
    +1,292
    If their box has a CI (Common Interface) slot, you can get a Top Up TV CAM to plug in it. If it has no slot at all then you're stuffed. Which box is it?
  3. Rob
    Rob
    Jul 17, 2000
    1,279
    Norwich
    +33
  4. E Thomson
    E Thomson
    Jul 22, 2005
    94
    looked at the link but the box is not on it. It is a samsung but I do not know the model number
