Freeview and Tivo
Discussion in 'Freeview & YouView' started by ScoobyZ, Feb 24, 2005.
  1. ScoobyZ
    ScoobyZ
    Sep 29, 2003
    1,093
    +140
    Hi I am looking to replace my freeview box for my Tivo.
    I did buy a ferguson one but it showed a slight flicker and I since read that this happens sometimes with the ferguson boxs, so plugged my old on digital one back in.
    Just looking for something compatible that I can use the IR blaster with and get from say Argos. I have read about the setpal ones but finding one at a less than silly price is hard at the moment.
    It has to go on a tosh 42" rpg too so pic quality would be nice. Also if possible the channel number displayed on the front, just to make sure tivo has turned it over :)
    Thanks in advance.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,599
    Rainham Essex
    +2,543
    Well most if not all freeview boxes are supported by TiVo for IR control. A full list of the recommended setup codes for TiVo to use for each STB can be found at http://www.tivoportal.co.uk under 'Supported STB's'.
    I have and can recommend for picture quality and overall performance the Sony VTX-D800U. the only thing it does not have is the channel display which I thought I would miss when I upgraded from my OnDigital box, but TBH I don't think about it any more as I have never missed a recording due to wrong channel on the STB (use code 20034 under manufacturer Sony).
    Mark.
