Freeview Aerials
Discussion in 'Cables & Switches' started by raygf, Aug 23, 2005.
  1. raygf
    raygf
    I have three rooms in which I would like to have TVs either using Freeview or analogue. Is it possible to run one aerial cable, to the three TV sockets in series or should each socket have a separate aerial cable from a distribution point at the actual aerial?
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    I would think that a booster box with 3 out puts would be better than running them in series. You will have less signal degredation from a booster in my opinion. If you run them in series and all the Tvs are on at the same time, i would have thought that the last TV in the line would get a very poor signal :)
    I could be wrong though.
    Dave.
  3. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    Cascading was the original way of feeding multiple tv outlets but it took smoe maths to work out levels and losses.
    Nowadays it is a starwired topology that is used, bringing the individual outlet back to a central location and using a 3 way amplifier.
    Most modern amps are designed to pass freeview now, although your aerial and cable feed may need replacing.
    Chris
