I have decided to get a new tv (hd ready) with humax box that receives freesat and allows me to record & pause live tv etc.
However, I don't want to have cables visible all around the outside of my house, and want them to be concealed...so will have to employ an electrician to do the cabling, before the dish etc. is installed.
What i need to know is:
1. what type of cable is required to go from dish to aerial socket? would shotgun cable be sufficient, or pt100?
2. how many cables are required - if i have 2 from LNB on dish to aerial socket, is tv aerial cable also required or does this become obsolete?
3. what has to be on the ends of the cables - f connectors?
4. i currently have 1 aerial socket, so when this is replaced, does it need to be with a double or a twin socket? (and does it need to be 1 or 2 gang)
thanks in advance,
carol
thanks in advance,
carol
