No Fun
Established Member
Hi Guys,
I have a LG EG960V, it's a great TV and has loads, however it's missing Freesat and picks up far too many channels when searched for and in the wrong order.
Would anyone with an Panasonic / Samsung / LG TV with Freesat be able to export their channel list so I can import it onto my TV (in the correct order and correct list of channels.
I understand Freesat needs a postcode, I'm in London (can a search be carried out on my London postcode to return the correct regional channels?)
Postcode W12 7GF will sort the channels correctly.
All I need is a channel export from a Freesat TV on the above regional sort for the postcode above.
I can then import this into my TV and sort the channels without going through 800+ channels.
Please can the file be uploaded to We transfer / Box / whatever other method.
How to export:
(Panasonic)
Samsung:
Starting with the C-series you can use the Program menu of your TV and select the option "Transfer channel list".
When asked for the PIN, enter 0000
When you select to Export the file, it will always be written to a fixed file name that matches your model. If it already exists, it will be overwritten without asking.
For info. I'll be using ChanSort to use the export as a reference file and then it'll match with my unsorted list.
See ChanSort:
GitHub - PredatH0r/ChanSort: TV channel list editor for Samsung, LG, Panasonic, Toshiba and VDR
Cheers guys! Shame LG won't enable the TV for Freesat.
How to export:
(Panasonic)
- Plug a USB Stick into one of the ports of your TV
- Select the menu option "Setup / Other Settings / Channel List Transfer" (or similar)
Samsung:
See ChanSort:
