Freesat box receiving no signal.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by CMOI1979, Aug 4, 2013.
  1. CMOI1979
    CMOI1979
    Aug 4, 2013
    3
    Hi all
    Long time lurker, first time poster.
    I am having problems with our Humax FOXSAT-HD box. Previously it was working fine but now we have ditched Sky and I have removed the box our upstairs Freesat box is no longer receiving any signal.
    We have a Sky branded quad LNB on the dish. Am I right in thinking that the Sky box would have been powering the LNB before whilst the Humax was just receiving a signal? Now the Sky box has been switched off the LNB is no longer receiving power hence no signal?
    I have been up the ladder and tried the Freesat cable in every port on the lnb so I am guessing the remedy is something not so straight forward.
    :lease:
    Please advise
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,534
    Redditch
    +4,184
    Any connected tuner will power the lnb. Connect the Sky box to the cable used for the Freesat box, does it still work ? If not check the f connector is correctly fitted.
    What happens when you switch on the Foxsat, does it just put up a message saying no signal ?
  3. CMOI1979
    CMOI1979
    Aug 4, 2013
    3
    I haven't tried the Sky box on the freesat cable as of yet. I'll give that a go
    The Humax boots up as normal but displays a message saying there is no signal.
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,534
    Redditch
    +4,184
    My guess would be the f connector at the box end isn't correctly fitted. Trying the Sky box will confirm this.
  5. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    Simply giving up Sky makes no difference to anything.
    It should simply have continued working, and you originally said you had tried all the LNB connections.
  6. CMOI1979
    CMOI1979
    Aug 4, 2013
    3
    So after being out with the family all day I finally got a chance to attach the Sky box to the cable upstairs.
    That too is telling me that it is receiving no signal.
    So what have I done wrong with the F-Connector?
    Do I need the shielding to be in contact with it in order for the current to be carried to the lnb?
    This is the cable I am using, it's about a 15m length.
    http://www.maplin.co.uk/25m-satellite-cable-kit-219428
  7. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    http://www.satcure.co.uk/tech/fconn.htm
  8. winston2010
    winston2010
    Jun 28, 2010
    1,895
    London
    +191
    Of course you do. Ideally F connectors should be of the crimp or compression type. Screw ons are a DIY bodge, but even Sky installers use them now. Thankfully the cable companies don't.
