freesat abroad
nabihaht
i'm in Malta and trying to get freeview channels as in the uk, i bought freesat receiver and installed it on a dish ,,, i could get the astra 2 and when i tuned the freesat i could finally get the tv listing with the guide but the channels don't show, it says no signal but i can still see on the bar what program is on, and when i scrolled down i could see aljazeera english only any ideas?
pedro2000uk
what receiver & what dish & lnb are you using
logiciel
Hi and welcome to the forum.
Freeview is terrestrial TV and can only be received within a few miles of each transmitter in the UK.
To advise on receiving satellite TV we need the details that pedro asked for.
Logiciel
Mark uk
Established Member
You are out of the footprint (range) for UK channels and even if you could receive them you would probably need a large dish.
This picture shows the reception area.
logiciel
The reception area from which satellite?
Mark uk
Established Member
pedro2000uk
It's not 100% set in stone, it's more a case of not taking the footprints as being exact but more an engineer's or artist's impression & then using bigger dishes, sensitive receivers/ lnbs, good installs coupled with local knowledge, but it is all a bit up in the air atm due to the recent changes.
kevkbuk
Yep, if you looked at the published foot print for the easy stuff at 26e and 7w you just wouldn't try in the UK...
Pollensa1946
Established Member
True. If you look at the Canaries they are also outside of the footprint but you can get reasonable reception with a 3 metre dish. Even with that monster it breaks up frequently.
pedro2000uk
We receive from this type of footprint ...
on 80cm/90c/1m/1.1m dishes around the UK pretty much everyday 24/7 with quite respectable rain margins but you'd think it impossible looking at the published footprints or you'd need 3-4-5m dishes looking at that.
Tight footprints like the Freesat spot beam over the UK are harder though- they're smaller & more focussed & they've worked on getting it tighter to restrict reception. We have a couple of much closer northwest Europe beams that can be harder than that MENA footprint.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
