Freesat 4k tv box
LiamG2000
I have a freesat 4k tv box and everytime I turn it on there's no picture and I have to keep resetting the box to get a picture
Can anyone help?
Rodders53
hdmi handshake issues most likely
1) try different hdmi lead(s)
2) try different hdmi input on TV
but also try switching TV to another input (TV tuner, alternative av input) and back to the freesat box to force a new handshake. (Rather than removing power from the box).
If the TV is UHD, and as there are no 4k broadcasts set the box to 1080i (or 1080p) rather than UHD with forced HDR? That may help. {Only change to UHD if you must use the box for streaming 4k stuff}
LiamG2000
Do I try changing the hdmi lead from hdmi2 to hdmi1
Rodders53
AIUI V1 is fine for HD 1080i as all broadcast channels are transmitted. V1.4 can do UHD at 30 fps so why not try it?
Do also check the supplied hdmi cable is seated properly in both box and TV set.
Do try the < force hdmi handshake > by switching TV inputs and back first - after checking the cable's seated properly.
LiamG2000
What V1.4
LiamG2000
Seems you've already done that hdmi input swap! ;)
Any improvement?
Also try another hdmi lead between the two units...
I, mistakenly, assumed freesat provided a Version 2.0 cable and you had a Version 1.x to use instead... ;)
That's worked thanks
