I had a Sky box with the HDMI feeding into a powered splitter, then 1 HDMI lead going to TV and the other HDMI lead going to my Home Cinema projector via a CAT6 convertor as it's about 12M cable length away. Audio to the TV is over HDMI but for the Home Cinema it is Digital Optical into an Onkyo Receiver.
All was working perfectly but then I decided to ditch Sky and recently bought a 4K Freesat Recorder (I believe it is manufactured by Arris).
I wired up the Freesat box exactly the same as previous on the Sky box, Picture and sound on the TV is perfect, however I have 2 issues with the Home Cinema...
1. I get virtually no picture on the projector - it flickers on and off, mostly off. I took the HDMI splitter out of the equation and connected straight to the Cat6 but this made no difference so it's not the splitter.
2. I'm only getting stereo audio feed out of the Freesat box, if I select "Surround" in the menu and save it just reverts back to Stereo.
Appreciate any suggestions from the group.
Thanks.
Thanks.
