freeloader
Discussion in 'Nintendo Forums' started by keyser, Feb 22, 2003.
  1. keyser
    keyser
    Jul 23, 2000
    901
    gardabaer, Iceland
    I have a us gamecube and live in iceland(pal). I was told at the local store that I can´t use the pal freeloader to make my us gamecube region free, that I needed to get one from the usa.
    Is this correct, do you need a usa freeloader to make a usa cube region free, and a pal freeloader to make a pal cube region free?
    I see there are 2 firmwares available, can they be uppgraded in the future or is it what you buy is what you get?
    How do the changes of regions affect the hz, will a pal game run in 60hz on a us cube etc.?
  2. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    What you've been told is wrong. The Freeloader itself is region-free and will allow any region Cube to play any region game :).
    What you buy is what you get. However v1.04 can be upgraded to v1.06 for free by returning v1.04 to Cidejunkies. As long as you get v1.06, you should be fine for the forseeable future.
    It's a bit hit and miss actually. Some do, some don't. All PAL games with a 60Hz option do though.
  3. keyser
    keyser
    Jul 23, 2000
    901
    gardabaer, Iceland
    Brilliant. I thought the store guy was talking crap.. weird how the guys at the stores never seem to know diddly.
    thanks groundy
  4. stewarthollyhead
    stewarthollyhead
    was worth reading this thread just to see that
    "diddly" has crossed the ocean to iceland
