Freeloader Question
Discussion in 'Nintendo Forums' started by j4y3m, Aug 1, 2004.
  1. j4y3m
    j4y3m
    Sorry if this is in the wrong section, you guys have a lot of gaming forums...
    I'm thinking about buying a Freeloader but I have one question...
    I know this will allow me to play imports from other regions on my PAL GameCube but will they be in full colour, with the screen centered on a non-NTSC television?
    Thanks for any help. :)
  2. t-force
    t-force
    May 2, 2001
    1,852
    Southampton, UK
    +143
    If you use an RGB connection, then you'll be fine. If you don't, and your TV is not NTSC compatible, you'll be playing in black and white.
  3. j4y3m
    j4y3m
  4. t-force
    t-force
    May 2, 2001
    1,852
    Southampton, UK
    +143
    The Cube as standard comes with a set of composite + stereo audio cables (yellow, red + white). I, in common with most people, would recommend getting the official cable (second out of the two you've linked to), as it seems to offer much better picture quality than any 3rd party cable. The only downside of it is that it doesn't have individual stereo output, so if you want to route through an AV system, you'll either need to take a signal out from your TV (if you've got stereo output), or use a breaker box.
  5. j4y3m
    j4y3m
    Thanks for the help. :thumbsup:
