Freeloader: progressive scan on a PAL GameCube?
Discussion in 'General Video Gaming Chat' started by olaiho, Feb 7, 2003.
  1. olaiho
    olaiho
    When using a FreeLoader and a PAL GameCube equipped with a component cable, is it possible get progressive scan with USA games?
    Has anyone had the chance to test this yet?
    BR,
    Olaiho
  2. NeoBlade
    NeoBlade
    Me and a few other peeps on this forums a while ago speculated about this... Yet I have not recieved my Freeloader yet so I can't test it... Maybe Groundy could? Hint hint <g>
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
  4. olaiho
    olaiho
    Darn it.
    Thanks for confirming this, Groundy.
    Regards,
    Olaiho
  5. nickb23
    nickb23
    Jul 21, 2002
    437
    Beckenham, Kent
    +14
    Does this mean that the hi def nintendo component cable works with pal gamecubes?????? i was under the impression it did not.
    NickB
  6. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    It works perfect :).
  7. nickb23
    nickb23
    Jul 21, 2002
    437
    Beckenham, Kent
    +14
    in the words of the fat tongue wa**er "PUKKA"!!!!!!!!!!!!!
    Where can i order one and for how much?
  8. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    I use:
    NCSX
    OR
    Tronix
    Import friendly and around £32 depending on shipping method.
    You could also try http://www.lik-sang.com but I don't rate them much ;).
  9. JamieD
    JamieD
    Dec 13, 2000
    93
    +3
    Eh? What would be the point? Would anyone be able to the tell the difference between component and RGB?
    I'm so gutted that the pal has had prog scan ripped out.
    jamie
  10. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    Well it probably isn't a proper comparison, but the Nintendo component cable gives a much better picture than the (non-Nintendo) RGB cable I bought from Game. Not sure if there's any difference between the 2 Nintendo cables.
    I too am gutted about the lack of PS on the UK gamecubes. I'm quite surprised too. I'd have thought that PS would be closer to the native output from the video hardware, and that this would then be converted to interlaced.
    Even if that's not the case, I'd have thought the cost of redesigning the video hardware to exclude the PS bits would have been more than any saving due to less parts.....
  11. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    The native RGB from the PAL Cube is certainly not the best I've seen, even from the official PAL RGB Cable. The Component Cable itself is of a much higher quality with triple screening etc. Also, using Component allows more flexibility as it frees up the Cube's Analogue Multi-Out for the sole use of sound transfer to an Amp/Receiver.
  12. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    I am under the impression that only Nintendo's own RGB cable is actually RGB, whereas the third party ones are all composite (even though they say RGB on the box). If you check customers' reviews on Amazon.co.uk this appears to be the case.
    Furthermore, I used Nintendo's own RGB cable, before switching to Nintendo's own component cable, and have to say it didn't look that different to me.
    Interestingly, RGB has more colour bandwidth and may be better suited to computer graphics; whereas video may be better suited to component. For example, are there any computer monitors that are CUY and not RGB?
    Why did I switch to component? So I can run GameCube through my progressive scan processor without having to convert RGB to YUC. Therefore I have every game in progressive scan, regardless of region, and they look fantastic!
    StooMonster
  13. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    There is only one 3rd party RGB Cable that works with the PAL Cube and it's made by Venom. I buy quite a few of them for use on my import RGB Cables.
  14. Richard Harnwell
    Richard Harnwell
    Sep 17, 2000
    315
    Colchester, Essex
    +4
    Well the RGB cable I referred to (from Game) is most definately true RGB. I can be certain of this because if it was only composite it would not have given any picture the way it was connected to my projector! The main problem with it though, was "cross-hatching" over some vivid/bright colours.
  15. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    The Game cable is definitely RGB. You can tell just by looking at the picture quality :)
    I tested it by using the RGB on/off switch on my switchbox (Argos). With RGB turned off the picture definitely gets fuzzy but with it on, the picture is incredible
