Freeloader and wavebird not compatable?
chrisnic0
Hi, ive got a silver wavebird from canada, ive also got a PAL cube but when I use the freeloader to play NTSC games the controller doesnt work at all. The light is flashing to say there is a signal?
When the game has loaded i have to swap the controllers round its a bit of hassle.
I was wondering if anyone has the same problems or can suggest something?
Nico
Orson
Hello there,
Mine are the standard grey wavebirds :( and work fine with UK cube & freeloader.
What we have to do when freeloader starts is press the red B button while it loads, and that does it.
Give it a try!
Kube
Cheers, i had the same problem :)
