Freelander Newbie Question...
Discussion in 'Portable Disc & Media Players & Recorders' started by Pyara, May 17, 2005.
  1. Pyara
    Pyara
    I have a JVC head unit with a 12 CD-MP3 Changer which I would love to install into my Freelander (W Reg - Millenium Edition).
    I wondered if anyone had experiance of doing this, particularly removing the OEM system and details on the cabling? (i.e. Do I need a cable adaptor)
    Thanks!!!
  2. btiffin
    btiffin
    It is possible that you will need an adaptor, Best to check with your local ICE dealer and see if they have any adaptors on file that you might need.
    I'm guessing this won't be a stock item so best order this.
    As for removing the stock unit:
    Have a look on it, does it have two holes either side of the unit?
