Freecom Mediaplayer-3 Connections
Discussion in 'Cables & Switches' started by leeparton, Sep 14, 2007.
  1. leeparton
    leeparton
    Having a bit of a problem finding the right connections for this, so I thought I'd put the question out there to see if anyone has had the same problem or can advise me on the right cables I need...
    The video output is claimed to carry a 720p and 1080i signal, but the video connection (labelled Video/YPbPr) apparently carries a component signal but is a 3.5mm mini-jack plug.
    I want to connect this to the Component input of my Samsung plasma or the VGA input (VGA would be better as I could also connect to my projector).
    Any clues? :confused:
    Thanks in advance.
    Lee
