freebee sky scart lead
Discussion in 'Sky Digital TV Forum' started by Ash007, Jan 7, 2002.
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    Is it generally recomended that u replace the scart lead that comes with Sky for a "better quality" one, or will this make little,or no difference, to the picture quality?
    Connecting sky to tv scart to scart.
    Any opinions?
    Ash
  2. mart.stokes
    mart.stokes
    Like all these things it does depend on the rest of your equipment. Spending £40 or £50 on an IXOS Scart lead to feed a 21" telly is probably overkill and you may not tell any difference. Spending £40 or £50 if you are feeding a RP Tosh or similar does clean up and brighten the picture.
    More expensive Scarts do tend to have better shielding therefore reducing the chances of other "nasties" though.
