Rasczak
Not sure if this is the right sub-forum but I suspect this is probably the best fit.
Can anyone recommend a self standing monopod suitable for a set of SkyMaster 25x100 binoculars?
I am lucky enough to have a living room looking out over Loch Lomond. The above binoculars are superb for viewing the wildlife but my current Tripod is a bit flimsy and I am struggling to find a suitable alternative. I want something that is sturdy (i.e it won't fall over if knocked by the kids) and preferably a monopod so it uses a small footprint in the Living Room. It doesn't need to be particular mobile as long as I only need to move it a few metres out the way or onto the balcony.
Can anyone make any suggestions?
