Free Space on Sky+ not available to record on
Discussion in 'Sky Digital TV Forum' started by greve, May 3, 2005.
  1. greve
    greve
    Nov 4, 2002
    For some time now, the free space on our Sky+ has 'grown' smaller and smaller and there is now more than 20% of the space which we can't access for recordings.
    At the moment we have around 30% space taken by recordings, around 45% free for new recordings and a block of around 25% seemingly unavailable.
    I have tried the 'HouseKeeping' trick without any change. Is the Full System Reset the solution and will I loose all recordings and future programmings if I do this?
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,608
    2
    In a secret location with Jennifer Lawrence
    +9,316
    The full (services 401) is the way to go. Had this exact problem and a reformat of the hard drive cured it. Gave me full space back. Unfortunately you do lose everything. Thats all recordings and all series links etc.
  3. greve
    greve
    Nov 4, 2002
    Thanks, that did the trick. Now I have 100% available again :)
  4. RichA
    RichA
    Apr 28, 2005
    49
    11
    Putney
    I have the same problem. Watched/deleted my way down to just one episode of 24 and I have only 48% free!
    Aaargh! Heard about the hidden '0' in System 401.
    Tried & tried but can't get it to work.
    Any tips? Thanks.
    Rich
  5. greve
    greve
    Nov 4, 2002
    I guess you mean you can't get the 401-trick to work. You may (as I did) not know that your have to press Select after you press Services 4 0 1. Try it - it should work.
  6. RichA
    RichA
    Apr 28, 2005
    49
    11
    Putney
    Thanks.
    Will try that tonight.
