Free sony VPSHU70W screen. Is it good?
Discussion in 'Projectors, Screens & Video Processors' started by frederic, Oct 20, 2003.
  1. frederic
    frederic
    I was offered a free screen with my sony projector. It's the VPSHU70W. Can someone tell if this screen is good?
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Well, it's free..........................;)
    Try using the "search" function, some members must have gotten these free screens with HS1s (is it a screen in an aluminium box that lies on the floor and the screen pulls up out of it ?? ....think they were sold as a package last year, iirc.)
    Sean G.
  3. Mirablo
    Mirablo
    Jan 16, 2003
    70
    Theyre OK .. not the best build quality but the screne is fairly flat. just check it retracts fully when you get it, and dont abuse it too much and it should be fine.
    check that it IS free and you cant buy the PJ elsewhere for cheaper. but without the screen....Free and bundled with are 2 different things imho
  4. paulw77
    paulw77
    Nov 18, 2000
    531
    28
    Wigan
    +41
    As theritz says, it's worth what you are paying for it !
    I saw this used in a demo with a HS2 and it seemed very flimsy and unsubstantial.
  5. MrSafety
    MrSafety
