Free satellite viewing
Discussion in 'Satellite TV, Sky TV & FreeSat' started by ianh64, Sep 8, 2004.
  1. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    My new TV (Loewe Xelos) will have an integrated digital satellite tuner - it comes as part of the Freeview tuner option.
    Without subscribing to $ky, can I make use of this to give me anything over and above what Freeview has to offer? Im quite happy with Freeview but it would be nice if I could access say Discovery and UK Gold at a nominal price.
    What would be needed, apart from a satellite dish and cabling?
    Ian
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There are plenty of FTA channels on digital satellite.
    You'll find a fairly upto date list here.
    I assume the TV will have a CI slot which means it could have a CAM for TUTV which will give you a few subscription channels for a price lower than SKY.
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Do I need a FTA card or something or can I just get a dish installed pointing at the satellite and tune them in?
  4. mevetts
    mevetts
    Oct 31, 2003
    439
    I have just moved into a new flat and have a similar question. Each of the flats are hooked up to a sat dish. Can I make use of this without subscribing to $ky or should I just get a normal Freeview box?
    Thanks,
    Mark.
  5. peggle
    peggle
    Aug 29, 2004
    155
    +23
    A SKY DIGIBOX and FTA card are needed for ITV1, C4, & C5 as stated in Starburst's excellent URL. You will not get them with the Lowe. However these channels and more like ITV2 are on FREEVIEW Digital Terrestial.
    The other channels in the list are available with the Lowe & a fixed dish pointing to the Astra2 Satellite.
    You could consider a motorised dish for greater choice. Contact an independant Satellite dealer for more info.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    As Peggle says a FTA channel needs no smartcard however ITV1, CH4 and Five require a SKY FTV card, expected to be officially sold for £20 later this year(some are being traded on ebay) however they can only work in a SKY digibox so would be useless for your television.
    Combine an integrated DTT/freeview receiver with TUTV and Dsat FTA all within the option package of the TV and you are pretty well covered:)
