Free sat annoying ...
Discussion in 'Satellite TV, Sky TV & FreeSat' started by onis_uk, Sep 18, 2007.
  1. onis_uk
    onis_uk
    Apr 30, 2005
    Right i just got a free sat card for my old sky box for the bedroom
    it shows all the channels in white and i can select them all...then it says you cant have this channel !
    how annoying so i dont know which ones i can watch and not ! is there anyother way of doing it ?!:confused:
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    using the navigator up and down key i think scrolls through the programmes you can get or alternatively spend a bit of time setting up favorite channels and use this feature
