Free or cheap OFFLINE docs creation/edit/save
Discussion in 'iPad Forum' started by simon12, Aug 26, 2013.
Tags:
  1. simon12
    simon12
    Nov 24, 2004
    907
    28
    +28
    Can anyone recommend an app for ipad that works simply to allow me to create word-style docs offline, retrieve them offline, edit them and save them offline? Being able to sync online later is fine. Ideally a free one of at least something pretty cheap. Does Pages work offline?
    I am using Documents at the moment and although it isn't bad, it won't do much fancy stuff like tables and if the item is created somewhere else and imported from Dropbox I can't edit it at all, only items I create with Documents.
