lbass
- Joined
- May 7, 2014
- Messages
- 7
- Reaction score
- 1
- Points
- 25
- Age
- 34
Thomas that’s exactly what I need! I can’t believe you have them all. Do you have a way you could share them with me?I have these
I will pm you…..Thomas that’s exactly what I need! I can’t believe you have them all. Do you have a way you could share them with me?
Thanks-- so there is no way to add the AVCHD Folder Structure to Favorites and/or give it a thumbnail?bartham;
This feature works on ISO and mkv containers.
marioni88;
The instructions are there:
FREE Oppo and Clones Jailbreak
FREE Oppo and Clones Jailbreak A huge thanks to: moremodey1 and to annonymous for the RU firmware! ________________________________________________________________________________________ Oppo-203/205 Owners Only...www.avforums.com
Ok so according to those "instructions" it is plug and play, just download zip, unzip, put the files on USB and connect it to OPPO?bartham;
marioni88;
i did my 203 last night and yes...just follow the instructions and it takes care of evertything. Just make sure to reset the player after the updateOk so according to those "instructions" it is plug and play, just download zip, unzip, put the files on USB and connect it to OPPO?
Nothing else.
Now sorry for my stupid question but if everything is so easy why we still need manual USB Method that is much more complicated and risky?
marioni88, If you have an Oppo-203/205, then THE FIRST thing you do is Backup its NAND!
Disclaimer: I'm not responsible if you Brick your device and loose Retail Blu-ray Disc playback!
The Auto_jb is for EU and USA region Oppo-203/205 and it needs the correct bdpprog to set it up right. Its more steps than the USB Manual Method.
i have 203 USA model.Marioni88, I totally understand. Thank you for the compliments Moremodey1 and anonymous and the others in page 1 post 1 of this thread deserve all thanks and credit. I just beta test, got the CN firmware paid and offer free support from time to time.
Now, knowing you have an Oppo-203/205 you are now, NOT to auto Jailbreak anything!
What model Oppo-203 or 205 do you have?
What country or region is it?
I will not help you any further or recommend Jailbreaking until you answer those above questions and can do TWO NAND Backups of the unit. That is it.
I have read that info.A USA Oppo-203 you would use: Auto_jb_ujb_bdpprog V1.1 USA. Inside that folder is: jb stk bdpprog folder. Inside that is the readme.txt file which you must read for further instructions.
I'll be here for any further questions and help needed. :-D
marioni88;
So, to confirm, you backed up your Oppo-203 (USA) NAND unit twice and saved all the 23 files safely somewhere on your PC/MAC and or USB Flash drive twice?
Lets be sure one more thing.
What is its current firmware that its on?
If its on USA Official UDP20X-65-0131, then you'll be using the USB Manual method with USA_with_Russian_JB folder contents put on the root of a USB Flash drive and follow page one post one instructions so you understand how its done.
I've Jailbroken my Oppo-203's on both methods. I prefer the Original USB Manual method. Nothing against Cle2000 and Liwil's work..
Thanks a lot for your prompt reply. For step 2, can I upgrade to the latest firmware from Setup Menu and select Firmware Upgrade / Via Network in the Device Setup menu? Please let me know.hitchahike;
1. Backup its NAND twice.
2. Upgrade your Oppo-203/205 to Official stock 65 firmware. Its on region Russian, so thats what it will upgrade to.
3. Then come back to page one post one and do the Manual USB method Jailbreak. Use Original 65 Russian to Russian JB.
