Not sure what that error message means but i could just try to explain how to run it so you could try:
My path to "
WinNFSd.exe" is "
C:\Tools\WinNFSd\" and in it i have the,
.bat +
exports.txt files (you must make these). Folder content looks like this:
The
important files are:
WinNFSd.exe,
nfsservice.bat,
exports.txt
-other files are for me when i forget things
the
.bat file content (
commands) is like this:
winnfsd.exe -id 0 0 -log off -pathFile "C:\Tools\WinNFSd\exports.txt"
the content of
exports.txt file is:
D:\MUSIC_WORKS
H:\O2REMUX_1080p
I:\O2REMUX_2160p
J:\TEMPORARY\
K:\-REMUXED-
K:\-REMUXED-\- LATEST
-make the first line empty (in exports.txt), apparently users have seen issues without it...:
-Now, the paths must of course be changed to the correct path according to your sharing folders.
Once the
.bat file is made just run it, then you will see in taskmanager that is running:
-at this point if no error messages are given then those folders are shared through NFS.
But remember to check your firewall. If your Oppo (obviously) is connected to the network
it would find the PC running
WinNFSd.exe,
but firewall would probably block it, so you will
need to unblock it. Once you try unblock retry to find the network in your Oppo.
Hope this helps, otherwise just reply or message me and I'll try to help
PS.
If you want the PC that runs WinNFSd.exe to start with Windows then do this:
press
WIN-KEY + R, type
shell:startup, then the Startup folder will open, then right-click and
choose NEW -> SHORTCUT -> and browse to your
.bat file, so next time Windows starts the NFS file will start automatically
