FREE Oppo and Clones Jailbreak
opponaut
@opponaut if you can dump the V60 that could be usefull , in V65 they implemented a protection that prevent from overwriting partitions from the OS in block device mode, could be nice to see what they changed exactly and eventually add it back.
Still not a game changer :)
Which partions would you be interested in? I do not want to share my key partitions, I am sure Oppo are among the players used as private source for certain decryption tools and I would not like to see the keys of my Oppo revoked.
opponaut
It worked, the backup of my Oppo on 60 (got a working download link from web.archive.org) is 23 files, 515.112.960 Bytes = 491 MB according to Windows on the first attempt. Seems about right, I am relieved that I know how to properly handle file systems. 7-Zip compressed on the default settings resulted in 131 MB.
If anyone knows why Oppo appearently introduced AutoScript with 56, I am curious.
theaxledentaldj
Opponaut, Im open to theories...? How the Russian JB was done? Because the found AutoScript and Teleneted in and or they just unpacked the firmware bin file? Did Oppo Digital engineers leave stuff behind because they knew they were leaving the market? Hmmmm🤔
opponaut
AutoScript is a MediaTek thing, some other devices execute it, too. That mostly found use for personal backup copies of SACD.
Some other MediaTek hardware also has or had hidden features i.e. certain disc drives.
moremodey01
do no share those that starts with KEY_ and MAC_ , the UBI_BOOT one is not needed either others are same from one player to the other and you can share it freely, in any case if it sent in pm to @theaxledentaldj or me, it will never be shared without your permission
snewton
Hi just like to thank moremodey1 for this jailbreak and massive thanks to theaxledentaldj who pretty much guided me through the (simple) process
DJBlade
Nice job but .. 👍
Simple process !?
I'd love to do mine but it does not sound so simple at all - maybe it's me who's simple ! 😁
snewton
Nice job but .. 👍
Simple process !?
Nice job but .. 👍
Simple process !?
I did contact moremodey01 and theaxledentaldj privately as you tend to get everyone putting in their opinion and it gets even more confusing
But it really is a simple process that takes a couple of minutes
dreadline
DJBlade,
Although it may look a little daunting, especially if you have not done this sort of thing before, it is an easy process
the instructions are precise in what you need to do and I found them easy to follow
Minuno
Could I ask if there is anything available for BDP-95 owners to downgrade the firmware to regain iso playback via USB.
quattroatl
Nice job but .. 👍
Simple process !?
I was hesitant and unsure in the beginning. I waited several weeks before I decided to install the jailbreak. I just read and re-read the instructions over and over again. It really is simple once you figure out what you want installed.
My path was backup NAND. Install RU jailbreak via USB on my US Oppo 203. Easy.
leev
Following this thread with interest. The main concern I have with the process is backup NAND. How is this done as it is not something I have any experience with?
Thanks.
dreadline
Thanks.
The NAND back up is the easiest part of the process
Basically, ensure you are on the latest official firmare
You find an old crappy USB stick (I think you stay clear of a USB 3 stick?) and make sure it is Basic, MBR, FAT32 formated.
You downloa the very small sized file from the first page of this thread and extract it to that usb stick
You put the stick into the front USB slot and your player should report that it has seeen the usb stick
You don't have to do anything more except leave it plugged in that front port for a while (I left it in about 5 mins) and then remove it and check on your PC that there are 23 files written on the stick
If there are, then that is the NAND backed up
I made a couple of copies of the files and stored them safe and that is how simple that part is
Once I had installed the jailbreak firmware, I did another NAND back up
So I have two seperate NAND backups, 1 before the jailbrake and 1 after the jailbrake
I am hoping that I never need them at all in future
leev
Thanks for your reply.
I will give that a go. Thanks again.
mattmarsden
Can anyone tell me if this firmware can resume with ISO files i.e if I stop an ISO part way through watching can I then resume it later? Thanks
theaxledentaldj
Max Doener, your prolly right. It depends on the authored movie disc title if they will let you resume or not. I've noticed some older Blu-ray titles don't let you go back to the menu so easily as some of the newer released Blu-ray titles let you go back to the main menu several ways.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
Latest News
Samsung's 110-inch Micro LED TV on pre-order at Harrods
  • By Andy Bassett
  • Published
Bang & Olufsen introduces Beosound Emerge speaker
  • By Andy Bassett
  • Published
Sony launches native 4K VPL-VW290ES and VW890ES projectors
  • By Andy Bassett
  • Published
AVForums Podcast: 14th April 2021
  • By Phil Hinton
  • Published
Ruark introduces R5 Signature audio player
  • By Andy Bassett
  • Published
