FREE Oppo and Clones Jailbreak
cskarev
theaxledentaldj, thank you. I will read everything again and I will proceed according to the instructions. I will write again if I have some questions or problems.
theaxledentaldj
I use putty .. I insert the ip of my nas
When I load the program I get black screen but no option to enter something on the screen ..
I really happy if you cloud help me with that
Is putty not giving connection info of Telnet?
Port 23 I think it needs. Although having jb_overlay v1 installed gives you sftp via Fileilla and you can see what mounted at /mnt/sda1 or not.
boy27
i will try with this software ... is there is password for oppo player ?
theaxledentaldj
Login: root
password: oppo
or it could be the other way around. Once jb_overlay v1 is installed, which is what I use, it wants all credentials.
Telnet by its self without jb_overlay v1, I think was just asking for root password: root
boy27
i tried with no luck in putti ( but i dont get option to enter password + user)
i also tried with filezilla with no luck
is there another option to enter to the player ?
theaxledentaldj
boy27;
Telnet is a tricky thing. Too many variables could cause it not to run or let you connect:
Router, Not running. Try, powering off and then back on the unit and try again.
boy27
ok my friend , so what are my option do you think ?
i have internt in my oppo
i chackd that the port 23 is open
theaxledentaldj
boy27:
1. You have right IP to the Oppo?
2. can you bypass router?
3. What error or what does PuTTY do when you attempt to connect to Oppo?
boy27
boy27:
1, i have the right ip on my oppo
2 . when you said bypass router you mean restart the the router?
3. in putty i enter the ip of the oppo and port 23 - and i get littel black screen ( from cmd ) with no option to writh somthing ? is ther somthing i need alse to set on the putty ?
theaxledentaldj
PuTTY should bet set to telnet.
Can you show your current AutoScript file again? Which I hope your using.
boy27
#MTKAT 0.xx script
CLI (CLI_exec echo root :: 0: 0: root ,,,: / root: / bin / sh> / etc / passwd)
CLI (CLI_exec / usr / sbin / inetd &)
SLEEPMS (1000)
CLI (CLI_exec / usr / sbin / telnetd &)
# CLI (CLI_app.vfdmg.b scroll_msg start)
CLI (CLI_exec mount.cifs // 192.168.1.163/ Public mnt / sda1 / Video -o user = *, password = *, ro)
# CLI (CLI_app.vfdmg.b clear_msg)
CLI (CLI_exec mount> /mnt/sda1/mount.txt)
i have 2 folder in the flash drive:
AutoScript ----- inside there is file calld AutoScript.TSS
video
Hope i doing right ..... my oppo ip is 192.168.1.101
theaxledentaldj
boy27;
I dont know if the CLi mount.cifs is an issue or not.
I thought its either UDP or TCP. Hmmm..anyone else got an idea?
telnet 192168.1.101 23
Connecting..192.168.1.101.
Oppo_Player login:
Works for my PuTTY:
Thomas Szucs
SLEEPMS (1000)
Try adding more delay - like start with 10000. If the Autoscript is run before the network is up and ready on the player then nothing works.
Start with the suggested 10000 (10 seconds) and if that works then try with lower values until you find what is best for you.
DubbyMcDubs
Full (1080p Frame Packed 3D) is only supported by a 3D Blu-ray ISO.
I have tested this on my old Samsung 3D HDTV several months ago. I was an avid 3D fan for about 4 years with that Samsung 3D HDTV.
Thanks! I will convert them to ISO and give it another go.
3D on the projector is amazing.
hlindstr
Never extract 3D discs or iso backups to BDMV folder structrure. It will lose its "magic wrapping" (<-- this relates to special SSIF folder under STREAM) and the extracted files typically take more space than what can be put to BD50 disc.
moremodey01
How do you create those iso ? I create the bdmv with makemkv then the iso with :
genisoimage -iso-level 4 -allow-lowercase -l -udf -V ALITA_BATTLE_ANGEL_3D -o ALITA_BATTLE_ANGEL_3D.iso ALITA_BATTLE_ANGEL_3D
This is correct right ?
Cconklin1
I have a 12TB disc with nearly every 3B BluRay Iso on it. All play fine on the oppo. I have been and always shall be an ISO guy even though it takes up a bit more space..
DubbyMcDubs
I have decided to redo all of my 3D discs to ISO. I tried a couple and they work now. Thanks for the tips guys!
Podcast: Sony A90J/A80J OLED details, Best type of Amplification, Film & TV Show News + Reviews
Latest News
LG offers best ever OLED prices - for one week only
  • By Andy Bassett
  • Published
Sony launches Bravia XR A80J OLED TVs in Europe
  • By Andy Bassett
  • Published
Tidal streaming service acquired by Twitter/Square's Jack Dorsey
  • By Andy Bassett
  • Published
Netflix adds support for reduced theatrical release window
  • By Andy Bassett
  • Published
Paradigm launches Founder speaker series
  • By Andy Bassett
  • Published
