Free Mp3 Editing Software
Discussion in 'Headphones, Earphones & Portable Music' started by realslimcookie, May 18, 2005.
  1. realslimcookie
    realslimcookie
    Oct 6, 2004
    243
    Hull, UK
    +3
    I am looking for some free mp3 editing software. I want to break up an mp3 into smaller sections so i can add one section to my mobile phone as a ringtone. Anyone know a good editor that works with XP.
    Regards,
    Realslimcookie.
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    This program is VERY good, and easy to use.
    http://www.polderbits.com/
    Unfortunately it is not free, but you do get a free 14 day trial so you can use it for your needs before the trial runs out.
  3. mick's cat
    mick's cat
    iTunes. Free and simple.
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    How do you edit songs in iTunes?
  5. mick's cat
    mick's cat
    Highlight a track, then choose File>Get Info. In the Options tab you can specify the start and stop time of the section you want. Click OK. Then choose Advanced>Convert selection to... (this will be set to whatever your Preferences, Importing tab setting is set to ie, MP3, AAC, AIFF, Apple Lossless, WAV etc at whatever bit rate - so you can specify a really low bitrate mp3 say, for a mobile phone). iTunes converts the track to the start and stop times, and import preferences you wanted. Job done.
    You end up with both the original untouched track, and the converted section.
  6. realslimcookie
    realslimcookie
    Oct 6, 2004
    243
    Hull, UK
    +3
    I have downloaded iTunes and will give it a go later in the afternoon. Cheers.
    Realslimcookie.
  7. davisneil
    davisneil
    May 15, 2005
    396
    +19
    google search for a free program called audacity.
    it lets you chop up sound files and edit them, also add effects, noise reduction, etc. very good, and its free!
  8. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    buy Nero6!
    Awesome piece of software given its price of around 25 pounds!
  9. hewesa
    hewesa
    Goldwave is excelent and you can convert any audio file to and from MP3
  10. Alcahest
    Alcahest
    Apr 10, 2005
    52
    I 2nd that, Goldwave is awesome to edit/convert audio files.
    Later,
    Alcahest
