Free Fox discs - missing UPN
G
graham.myers
Now the free Fox discs have started landing on our door mats, those of use have DVD Profiler may find it difficult entering the title in our databases. This is because the discs have a "promotional use only" block where the barcode/upn code would normally live.
The profiler database is not that hot on R2 discs in the search. It knows about them when you enter the upn but very rarely lists it when searching by name.
So...
Can anybody with the R2 versions of "What Lies Beneath", "The Full Monty" and "Dr. Dolittle" kindly post the upn numbers for these titles.
EAN stands for European Article Numbering. Generally, EANs may be found on the back of the DVD cover, and printed under the bar code. Region 2 EAN's are generally 12 digits
thanks in advance
Lex
You can enter discs by their title as well as UPN.
Lux
full monty
Barcode: 5039036003018
WLB
Barcode: 5039036006378
dr dolittle (eddie murphy)
Barcode: 5039036005715
all from www.dvdstreet.co.uk
CodeThief
Free Fox discs, I must have missed something???
Dave
S
Squirrel God
You must be doing something wrong because I have no problem at all entering disks by title.
Make sure you click "Advanced Filters" (on the far right, on the same line as where you enter the title). Then you can select which Regions you want to search under.
Lux
I actually had the same problem but with R1 discs. My profiler had R2 as default so didn`t display R1 and R4 when looking for a title
G
graham.myers
ah something new for me - thanks for that
S
Squirrel God
It won't do, unless you specifically select "All regions" or "Region 2" or "Region 4" etc using the advanced filters.
Lux
I know how to do it now. Hence the HAD in my post;)
cheers
Lex
Apparently you don't check the Special Offers forum very often! ;)
I got Full Monty & What Lies Beneath this morning. :)
CodeThief
Thanks guys,
Signed up anyway :)
SquirellGod :(
Dave
Y
yatesd
Was planning on creating a database of my DVD's, which I guess is what DVD profiler does.
Can someone tell me where I can find out more information on it??
Thanks,
Dave.
Lux
u can get the profielr from herehttp://www.dvdprofiler.com/dvdpro/index.html
downlaod it, install it, setup is a piece of cake
U just need to enter the UPN code of the barcode and the profile of that DVD get's loaded and u just add it to ur collection
HTH
