Hi all,
I've been confused by depth of field calculations. I found a really good online depth of field calculator here, but it's not much good when I am out & about.
I thought that someone must have written one for a mobile phone. A quick Google, and I found a free DOF calculator application for your phone here!. It is a java app which works very well on my SonyEricsson w910i and should work fine on any java capable handset. Some of the text formatting is a bit off but I have a slightly wider screen than most handsets.
Works very well. I've compared a few results with the DOFmaster site and they match up to within a few centimeters.
Dont forget to set up your sensor size in the options!!!
If you do download it and have PayPal, bung the guy a few quid using the "donate" button as I've done - it's only fair.
Tobers
edit: It also does angle of view for helping with panoramas.
Tobers
