free air sub????
Discussion in 'Subwoofers' started by azmibadres, Feb 28, 2005.
  1. azmibadres
    azmibadres
    :lease: ....can i use a box for free air sub?
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,122
    notts.
    +78
    :confused:
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Are we talking about using a car sub for HC use?
  4. Nimby
    Nimby
    Jan 27, 2004
    9,267
    The Danish Bacon Factory
    +710
    Just another wild guess: But it sounds as if you mean using an infinite baffle loudspeaker driver (or drive unit) from a car by putting it into a box instead of using the car itself as a baffle?
    By "infinite baffle" I'm not talking about a closed box. Which is not an infinite baffle and should never have been called that in the first place.
    Nimby
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Agreed.
    I can't really make out what is meant by the original poster at all although I've got a couple of half ideas. Can we have some more info as to what you're trying to achieve please? :)
  6. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    It all depends on the driver in question, some you can some you can't.
    Free air is actually a term held by Kicker.
    IB or Infinite Baffle can be achived both in the home or in the car.
    I will need to know:
    a) What driver make/model it is?
    b) Where it is going to be used?
    Before I can properly answer the question.
