Framing issues??
Discussion in 'Computer Components' started by (GTV)Chris, Oct 24, 2004.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Does anyone know why..... When I put different movies on I am permanently having to zoom in or out by a small amount to re frame the shot.
    Windows 2000 is perfect, then I put on a movie and it shifts left a little so I have to compensate.
    Then another film will be ok and I have to pull it all back...
    Is there a reason for this.
    I use TT 1.5 btw.
    PT AE500
    Chris
