frame dropouts on software dvd player
Discussion in 'Computer Components' started by jason t, Jun 17, 2001.
  1. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi guys
    well i have built my new htpc,and it seems to keep dropping frames can any one please help????
    i have direct x 8a installed
    the latest beta drivers for the raedon
    the specs of my pc are
    abit kt7a
    athlon thunderbird 1.1 ghz
    256 meg pc 133 ram
    creative 6x dvd drive
    ati raedon 32 meg ddr
    thanks
    jason
    :confused: :confused:
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,738
    7
    2
    167
    Birmingham, UK
    +10,628
    What refresh rate are you using?
    What is your display device?
  3. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi at the moment i am using a 17 in monitor at 75hz playing r1 and r2
    jason
  4. KimBowers
    KimBowers
    Jun 18, 2001
    5
    London
    At the risk of asking the obvious jason, have got got DMA checked?
  5. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,738
    7
    2
    167
    Birmingham, UK
    +10,628
    Region 1 should be played at a multiple of 24 fps - e.g. 72Hz
  6. Metric
    Metric
    pal is 25 fps? so 75 is best?
  7. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    yes guys dma is definatley enabled !!!!
    i have been reading on the avs forum and they seem to think 60hz am i missing something i am new to htpc,i seem to be having a nightmare and i havent even tried connecting it to my projector .
    all advice and setting are welcome
    jason
  8. HT Dude
    HT Dude
    Have you tried NTSC at 72Hz?
    Also does your monitor display the refresh rate being fed to it? If so what is it reading?
    [ 19-06-2001: Message edited by: HC Dude ]
  9. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    Which DVD player(s) are you using and what OS?
  10. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi i'm using m e with windvd 2.1
    when watching a film you dont tend to notice it but if you watch the time you can see it occasionally skip 2 seconds
    i tried it last night on my plv30 and was really impressed with the picture,i slightly defocused so i did'nt notice the pixels
    brilliant
    jason
  11. Arthur.S
    Arthur.S
    A couple of obvious things to try; Check that graphic acceleration is set to full. Shut down any programmes running in the background. (CTL+ALT+DELETE) You could also try a different decoder. 'Power DVD' is available as a free download.
