Do all the FragFX's come with a mouse mat? I've just received my FragFX v2 and there wasn't one. I'm guessing only the higher spec ones have it?
The 2 Frag Fx v2 i had both had a mouse mat in
I had an earlier XPFS a year ago and yes, you do need to run these and the XIM type of devices through a PC or conveniently placed laptop.
For those that are ok with this, the performace I believe can be superb. Personally speaking they don't suit me hence my preference for a FragFX or Fragnstein but they are well liked by some.
Glad to see that Bannco are doing their best to get to the root of your RF issues.
Are you registered on their user support forums? There are some good and constructive discussions there between users and Bannco and a fair bit of help too.
You are wrong, mate. This adapter do not need any pc or laptop to work
XFPS Rateup adapter for PS 3
Just plug kb and mouse in it and play, all binding can be done with buttons on it and siaxis ps3 controller. But i can't find any reviews on this device, comparing it to spitfish or fragnstein.
I had Frag fx v1 and it was really terrible when i tried it, almost unusable in KZ2, even after all possible adjustments and firmware updates, so now i'm a little bit worring about buyinf the same thing with another name.
Also to let you fragnstein guys know there is a newer firmware update out called "Expert Firmware V1"
it addresses the deadzone and the mouse acceleration that I deemed making the mouse a challenge to play a smooth game without having to worry about the mouse accelerating too much with small movements and no acceleration with too much mouse movement.
Will check it out later today to see if it solves anything hopefully it should!
Thanks Bigskill89 I noticed this on the Bannco forums earlier this morning and decided that it was worth being half an hour late to work in the name of testing and research of course
There is a definative difference in how it functions over the previous firmware. I like the less deadzone and it does seem to be even smoother, although as ever, I changed my RF to 5. I'd gotten too used to the mouse acceleration but it's clearly an additional improvement.
Bannco suggest in-game sensetivity at 4 with 0 clicks of the mouse wheel. I found this to be a little too slow so pushed the mouse wheel up to 4 clicks, which did the trick for me. Played half an hour of Special Ops and loved it.
Simpleguy - sounds like your problems may be solved. Let us know how you get on once you've had more fun with it
I think you should tell your notes on last firmware to developer about mouse sens in Bad Company, because most of the ppl now use MW2.
Hi guys,
I've tried out both Expert Firmware 1.0 and 1.1 so here's my feedback.
1.0 seems to have a slight issue with Y-axis mouse movements - it's not as smooth as the X-axis movements.
1.1 appears to have fixed that issue somewhat, but personally, I still feel there's room for improvement as the Y-axis mouse movements are still not at par with the X-axis movements, which are great. You'lll notice the difference when you make minute movements along the two axis.
However, having said that, that little shortcoming is not a deal-breaker as you can still play a decent games, particularly with the improvements in the aim speed as well as the now off-by-default scroll wheel look. I think you can switch it on if you prefer it, but I haven't tried that yet.
Errr... this thread seems to be a little quiet lately... are you guys busy fragging away with the new firmwares?
Hi Simpleguy - thanks for the updates on the newest Bannco firmware. I was using Expert 1.0 and probably had similar niggles to you with it but then again found it playable and an improvement.
I've been sent away for 10 days with work (currently sitting in departures at Manchester Airport) so won't be in front of my PS3 for about a week. I'm sure there'll be more firmware updates out by then but can't wait to get back and to play with the Fragnstein further
I also should hopefully have had my replacement FragFX Pro delivered to my office sometime this week so I'll get the chance to try that out next week too.
Enjoy the Fragnstein
So you guys advice to buy fragnstein instead of latest frag fx pro wireless ?
