FR Recording Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by sdm197, Jul 8, 2003.
  1. sdm197
    sdm197
    Apr 21, 2003
    202
    South East London UK.
    +13
    Hi everyone,
    I was setting up the recorder today to record 2 hrs in FR for one program, will this actually be superior to using SP., also if you were recording for 1 hour in XP would FR be better for 1 hour too??
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    All FR does is adjust the program file size to exactly fir onto a dvd.
    In the two examples you quote it would be nearly identical in quality, but still slightly worse as it will have to process the picture to convert from one to the other instead of a direct copy.
    FR is intended to exactly fit an odd length of program onto a dvd whilst getting the best possible quality, ie 90 mins at fr filling a dvd is better quality than at sp with 30 mins of dvd spare.
