fq75 & ps2 problem
Discussion in 'General TV Discussions Forum' started by Ashy, Mar 17, 2003.
  1. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    Having a picture problem when ive got my ps2 on. In the top left corner of the screen it bends in slightly which is immensely annoying :(
    Im using the lead that came with the ps2 and its plugged into a scart at the back of the TV.
    Anyone any ideas how this can be remedied?
    Ash
  2. nathan_silly
    nathan_silly
    Is the PS2 on top of the TV?
    Probably the PS2 power supply effecting the TV..
    If not sounds like geometry problem.
  3. Ashy
    Ashy
    Jan 3, 2003
    377
    +14
    hi mate
    the ps2 is right at the bottom underneath the stand, it also gets pulled out from under it when playing due to length of ps2 joypad cables so i dont think its that.
    if its a geometry problem how do i go about fixing it?
    Ash
  4. nathan_silly
    nathan_silly
    Need to go into the service menu, you can adjust some settings- pincushion, trapezoid, parr, hori/vert. placement etc.
