FQ75 muting itself and red flashing light?
Discussion in 'Televisions' started by andrewmellor, Mar 24, 2003.
  1. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,507
    38
    Nottinghamshire
    +18
    It's happened just a couple of times but I'm now going to log it as a fault and get it looked at but I thought I'd post on here and see if you could diagnose it for me,
    Its a Sony 32FQ75 and what happens is it will swith the volume down by itself, the bars going down on the screen to zero and staying on screen at the same time the red standby? light is flashing on and off.
    If the volume is turned back up it seems fine again though.
    As I say it's only a few times but it seems to be a definate fault with the set and is quite annoying....any ideas???
    thanks for any help..Andrew
