FPS + Projector = nausea
Discussion in 'Nintendo Forums' started by RichKS, May 10, 2005.
  1. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    I recently bught a projector and started using it with my consoles etc.
    The problem is that while most games are fine, SOME first person games make me feel quite queasy. Doom 3 doesn't seem to have this effect, but Timesplitters 3 does. Haven't really had a chance to test this extensively with every title. It used to happen occasionally about 120 years ago when I used to play Doom and Heretic on my PC, and then it seemed to happen when I was tired or had low blood sugar. Again, haven't tested extensively, so I can't be sure. Does anyone else have this problem? Anyone know how to avoid this?
  2. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,981
    167
    The Wheldon Road end!
    +8,121
    Quite a few people had problems with HL2 which were akin to motion sickness. Also DLP Projectors can cause some people to feel ill during fast moving scenes/games through what is known as the Rainbow effect. Do you have a DLP, LCD or CRT projector?
  3. PiePie
    PiePie
    In the options for Time Splitters 3 is there an option to decrease the "view bob"? That should help if it has one.
  4. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    I found that it did initially but now I must be seasoned to it and have no problems. However if others view it while im playing they have the same problem. I guess its a similar thing to feeling car sick when your a passenger!!
    Stick at it, you may find it will pass and then you can enjoy games at a fantastic size, especially GT4 in 1080i on an 8 footer it is superb :thumbsup:
  5. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    I can't play any first person games for any more than about 20 mins. I even get queasy thinking about them. I first noticed this with Doom II all those years ago.
  6. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    It's an LCD. I've never had this problem with my TV (32" widescreen). I used to with my PC, but haven't been able to play games on my PC since Unreal Tournament destroyed my tendons about 6 years ago. I guess it's something to do with the % of your field of vision that the moving image takes up. Close to a 17" monitor I suppose the screen takes up a large %. 2 metres from a 32" TV, and the % must be far less. 3 metres from a 2 metre screen, and I guess the % is pretty big again.
    And sorry, I meant 10 years ago, not 120 (but I guess you'd have to be a bit special to think I'd been playing Doom 120 years ago...)
  7. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    Now, that's a good point. My girlfriend had to look away from the screen the other day while I was playing GTA the other day. But then she's been known to fall over while watching other people play games in arcades :D
    I always did feel a bit squiffy watching other people play FPSs. Something to do with knowing which way the screen is about to turn.
    Gah, videogames without violence are like vegeburgers: they're alright, sometimes even fun, but you can't help feeling that you're somehow missing the point :D
  8. aligebes
    aligebes
    Jan 2, 2004
    229
    Edinburgh, Scotland
    +3
    It may seem stupid, but how far back are you sitting from your screens? I believe there is a minimum distance you are supposed to sit away from a large screen? The closer you sit to a large screen, the more likely you are to suffer from eye strain.
    We use a PS2 linked to a 6ft screen via a Sony VPL Cs5 projector and have not suffered these symptoms.
    I would also suggest buying a joypad extension cable for the Xbox so that you can sit further back from the screen.
    Also for those that use VDU's at work, treat the console on the same principle, have a break from playing for 20mins or so, I think at work you have to go away from your screen for at least 20mins every 4 hours. Someone may explain this a bit better than I have.
  9. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    i get the same problems on TFT monitor, my Pj or my widescreen tv. certain games affect me some dont. far cry and halo2 didnt effect me were as HL2 and Ts3 really got me after about 30 mins play.
  10. nero0410
    nero0410
    Jan 5, 2004
    11,658
    southwest
    +4,434
    I used to have the same problem when I first got my projector.
    Perserverence worked for me, after a couple of weeks I got on fine with it and still do now.
    It's great when you finally get used to it
    tris
  11. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    Heh, it's not the controller cable that's keeping me near the screen, it's the wall behind me! The consoles and projector are mounted on a shelf on the wall behind me.
    Darn, I think I'm going to have to do extensive testing on this effect :D
  12. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Well knock the bloody wall down then fella :thumbsup: ;)
    Matt
  13. PiePie
    PiePie
    If it is a distance issue, it might be because the screen is so large that the parts of the image that goes to your peripheral vision is distorted. What I mean is because, peripherally, you'll looking at the image side on instead of directly, which causes a distorted perception and so can knock you sick.
    If any games have a curvilinear view (so called "fisheye" but in reality it's how the eye receives data) that can be adapted to huge screens that should cure ithe nausia
  14. aligebes
    aligebes
    Jan 2, 2004
    229
    Edinburgh, Scotland
    +3
    This is what I hoped someone would post!!
    Thanks PiePie
  15. PiePie
    PiePie
    Cool, thanks. I kinda hope more games start using curvilinear geometry - although they look odd on small screen on a larger screen you get a more realistic image - and if the panoramic, "insideofagiantball" displays are made the emersion and realism would be staggering. Not likely to happen though lol :( but I know there's arcade games that use something similar.
    The only game I know that uses curvilinear perspective is Fisheye Quake. Shame it uses the DOS version of Quake though - the low resolution doesn't do it justice.
  16. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    Well, 2 hours of TS3 after a slap-up feel last night left me feeling anly slightly frazzled. Which might have been because of the frantic action rather than the screen size. Either I'm getting used to it, or it's really related to blood sugar.
  17. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    I have come full circle on this really. I started out thinking the PJ was a bit much for FPS moved back to the Plasma now I`m back on the PJ.
    It does take some getting used to but looks fantastic :)
  18. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,981
    167
    +8,121
    I must say that i've hardly played games via a TV since getting my PJ. The PJ gaming experience is just so much better and immersive that I find it a very unrewarding experience going back to using my 32" widescreen Sony.
  19. Dr_Mike
    Dr_Mike
    Mar 10, 2004
    367
    Loughborough
    +16
    Had a go the other night with my PS2 plugged into a borrowed LCD projector. Played GT4 and Colin Mcrae. Started feeling really rough after about half an hour which is surprising as I've never suffered from car sickness or other motion sickness. I was at about 1.5 to 2 x screen width.
    Had been looking forward to a bit of big screen gaming when I get round to getting a PJ. Now am not so sure, but it sounds as though some people can get used to it.
  20. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    What I'm seeing is that if my blood sugar's low I feel squiffy after playing an FPS. If I play while I'm perky, it's all OK.
    Try playing just after you've eaten.
    Rich.
  21. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    I've had a projector for a few years now (AE100) and while don't suffer from any symptoms from using it do find it slightly harder to obtain high scores and complete difficult levels. So often when it comes to difficult games I go back to using my 100hz thomson 28" widescreen. Is that just me or do any others find it more difficult to play games via projector?
