FPS Freek thumbstick add on.
Discussion in 'Xbox Forums' started by nonemoremannion, Jan 31, 2009.
  1. Hillskill
    Hillskill
    Moderator/Games Reviewer
    Mar 10, 2005
    22,842
    Somewhere being wrong but staying strong
    +5,647
    Will these fit on my Rapid Fire controller ?
    :devil:
  2. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    Let me know how you get on Hillskill and I might purchase a pair :rotfl:
  3. Hillskill
    Hillskill
    Mar 10, 2005
    22,842
    +5,647
    Just spent a ton of cash on a Lag switch so these may have to wait a while ;)
  4. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,863
    127.0.0.1
    +7,680
    i didnt know you were planning on playing halo 3 steve ;)
  5. Satsui_Ryu
    Satsui_Ryu
    Sep 22, 2008
    5,083
    +693
  6. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    Thought id update my experience with the GETZ thumb grips.
    Had them around 1 or 2 months now. Im not really a big gamer on my xbox maybe around 15hours a week. Grips are good, but i have noticed the rubber that goes under the thumbstick has warped slightly and my grip kept coming off. This is from me pushing up on the thumbstick but i have rotated it 180 degrees so the warped bit is at the top and its fine again. I assume the same will happen tho and ill have to buy a new lot, unless some boiling water will reshape them. Also the tiny groves on the top have started wearing away, i did expect this but not so soon.
    Overall: 8/10
    (Would of gave them 9/10 if they didnt warp)
  7. uchiharonaldo
    uchiharonaldo
    Mar 18, 2009
    154
    Lancaster
    +8
    would be a good idea for PS3 as the anlogue sticks are horrible, are built round and are slidey. 360 pads however are perfect. no need for these mods
  8. TcT Sid
    TcT Sid
    Nov 17, 2008
    6,063
    +1,373
  9. Chrisoldinho
    Chrisoldinho
    Feb 7, 2006
    3,445
    Leeds
    +267
    Well nearly 5 months on from buying them and still very impressed with the Geltabz. The tab that sits over the left analogue stick occassionally falls off but I think that's down to my tendancy to always make the "Z" logo straight on the controller which over time twists it off the sticks handle.
    Feel is very good, even when you get a bit moist :D
    Am going to buy some for my Dad as a fathers day prezzie because he loves COD and he's played it so much the grips on the handles have worn down :cool:
  10. Gordon B
    Gordon B
    Dec 29, 2006
    6,091
    +1,061
    Whats the service like from The Gametrain? Need to order some more but never heard of them as a company.
  11. Satsui_Ryu
    Satsui_Ryu
    Sep 22, 2008
    5,083
    +693
    I received my order in 2-3 days.
  12. soltakr
    soltakr
    Oct 27, 2005
    1,297
    Cov, UK
    think im gonna buy a set too. we'll see how they do.
  13. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    I completely disagree. Although the PS3 sticks are rounded they do have a larger surface area, and it is textured. The sticks are also less stiff than the 360's. Also you can't use them with a Wireless keypad because you don't get full stick movement from them. There's just not enough room, bit of a pain really.
    I'm still using the same set of Caps4stix I've had for months. They're a bit flatter than they were at first but the larger and more gripier surface area is a big improvement.
  14. GMC79
    GMC79
    Apr 1, 2006
    10,660
    Glasgow
    +3,184
    I use blutack on left stick, sure im not the only one to try it :) Not on my main 360 controller but on my wired pad i use for my PC, helps me be smooth on the steering on the likes of rfactor etc by keeping movement while gripping it to a minimum..
    Also used blutack on my PS3 triggers till the real triggers were around, useless without something they are.
    Good stuff it is! :rotfl:
  15. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    After one of my GETZ grip kept coming off i decided to try re-shape it with boiling water.... didnt work lmao
  16. soltakr
    soltakr
    Oct 27, 2005
    1,297
    Cov, UK
    what the hell, yesterday (and today) it said the blue ones are in stock and quote 'Order today and we'll post this tomorrow!'
    and i get email today saying delay of 1-2 WEEKS!! and they already took my money.
  17. Pebb
    Pebb
    Dec 29, 2005
    13,155
    Eastleigh
    +829
    At least you can still buy the pink ones. :rotfl:
  18. Satsui_Ryu
    Satsui_Ryu
    Sep 22, 2008
    5,083
    +693
    I wouldn't recommend the Geltabz to people that intend on using them with games like UFC or Fight Night. Mine were ripped to shreds within a couple of hours. They held up well with all other games though.
  19. soltakr
    soltakr
    Oct 27, 2005
    1,297
    Cov, UK
    im just gonna sweat it out, seems someplaces dont have them instock atm.
    pink doesnt go with my red nail polish, you know that hun. :rotfl:
  20. Chox1988
    Chox1988
    Mar 30, 2005
    16,796
    basingstoke
    +9,163
    :rotfl::rotfl:
  21. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    Do NOT use these if you play fight night!
    I bought myself a replacement pair and they've lasted a week with hardcore sessions of fight night round 3 and 4!
  22. Chrisoldinho
    Chrisoldinho
    Feb 7, 2006
    3,445
    Leeds
    +267
    LOL I ordered them last Tuesday 16/06/09 for a Fathers Day prezzie and they arrived the following day. It might of helped that I left them a little note advising them the reason I needed them quick!
    The original set took about 10 days to arrive, however this was due to an Administration error at their end to which they apologised unreservedly :thumbsup:
    The left grip falls off occassionally (usually after i've been twisting it so the logo is straight) but it's so plyable now it only takes 10 secs to fit it back on.
  23. soltakr
    soltakr
    Oct 27, 2005
    1,297
    Cov, UK
    forgot all about this, itll be 2 weeks on the 30th, then ill be ****** off if they dont come by then. either i hope they have arrival on 30th or atleast changed from 'processing' if not then cancel. they never said anything about importing taking this long.
    i ordered at 6pm so you might have got the last pair or something.
  24. |Pro|
    |Pro|
    I'm better without these..
  25. Mr Noble
    Mr Noble
    Sep 28, 2008
    17,198
    Gateshead , Tyne & Wear
    +4,022
    +1 :smashin:
  26. virtual_boy
    virtual_boy
    May 21, 2008
    2,538
    Isle of Man
    +445
    My FPS Freeks just arrived, will try them out later and post back.
    Was having a look at those Gel Tabz and found these, anyone going to admit to buying them?
    Might make a good gift for a laugh.
    Lock 'n' Kill Adhesive Target Reticules - £1.95 : TheGameTrain.com
    EDIT: Just tried my freeks and on my first match (CoD4 hardcore team deathmatch) I got 20 kills and 6 deaths and that was without wearing my astros.
    So if I add my score of 27 for 4 with my astros and 20 for 6 with my fps freeks I should be able to get about 47 kills and 10 deaths using both lol
  27. mudstuff
    mudstuff
    Apr 28, 2008
    3,634
    Milton Keynes
    +412
    Good to know, I'm curious about these. So do they make large movements quicker or make you generally more precise? I assume being raised gives you greater accuracy? Sometimes in FPS and shooters etc, my aim flys around the screen and I'm not too accurate or I'm over-excited lol. You reckon these would help then?
    Couple these with my Astros and I could be a deadly weapon?! :)
  28. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    These crosshairs and a modded controller... :devil:
  29. mudstuff
    mudstuff
    Apr 28, 2008
    3,634
    Milton Keynes
    +412
    Picked up some FPS Freeks, should have them early next week and will report back if they help.
  30. soltakr
    soltakr
    Oct 27, 2005
    1,297
    Cov, UK
    i ordered mine on the 16th of june and thought id give them till weekend and still no show and no email since 17th saying delayed 1-2 weeks. TERRIBLE. emailing for refund monday.
