foxsat hdr wont give widescreen
thyristor44
Hello
Im having a slight problem with my foxsat hdr. I have recently noticed that it isnt giving out a widescreen picture to my Panasonic viera tx L32e5b, picture is about 40mm of black each side. Its connected hdmi cable. I dont have the same problem with the dreambox 2 on other hdmi port.
Any ideas
thyristor44
PS its Raydon modded.
grahamlthompson
In memoriam
On the Foxsat-hdr Check Menu/Settings/Screen Ratio is 16:9.
Check you haven't pushed the wide button on the remote. If so cycle through the options to get the right screen aspect ratio.
thyristor44
I tried that on all settings and the display settings but still there is 40mm black strip either side.
Any more ideas please
kevkbuk
Try the Foxsat on the input in use by the Dreambox, that'll tell you if it's a Foxsat or TV setting at fault as the TV settings generally input specific.
thyristor44
No that wasnt it, still short on width.
I did think of going back to standard firmware as a try. Have you ever heard of this causing any width problems.
Or any more ideas.
grahamlthompson
In memoriam
A while ago I vaguely remember a similar problem with a Panny and HDR. It seems to be related to the way WS switching is handled on hdmi. It wasn't related in any way to the custom firmware which doesn't alter the Humax settop application in any way.
Can the OP see what happens if 4:3 is selected on the HDR and vformat is set to 1080i (not original).
thyristor44
Can you explain the last sentence for me please.Also what is WS switching.
logiciel
The machine's menu system preumably has a video settings menu and on that you can specify a selection for picture dimensions such as 4:3 and one for screen resolution such as 1080i.
WideScreen.;)
caldirun
Hello
Any ideas
thyristor44
You may have 14:9 screen ratio selected for the Foxsat, on the Panny, it is input specific.
When the Foxsat is the input source use the Panny remote and press the button below the power button marked Aspect to cycle through the Panny ratios, select Auto or 16:9.
thyristor44
That did it, back to full screen width. Thank you very much cauldron.
Also thanks to others for their help too.
All the best
thyristor44
caldirun
All the best
thyristor44
Great, I will forgive the username transgression, just click the "Thanks box" at the bottom of any helpful posts, its nice to think you have helped someone, even in just a simple thing such as this.
thyristor44
Sorry caldirun, small laptop screen and no reading glasses.
logiciel
Which gives me an excuse to ask - why on earth do they refer to the thing with the flames in as a cauldron?:confused:
You put fires under cauldrons and put potions in them.
grahamlthompson
In memoriam
