Question Foxsat HDR running Raydon 4.0.1 freezes
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Ayrton, Jun 10, 2015.
Tags:
  1. Ayrton
    Ayrton
    Dec 4, 2002
    649
    Leicestershire
    +21
    I've been running Raydon's firmware for a couple of years without issue. Recently the box started freezing occasionally (though increasingly often, I think) needing a hard reset using the rocker on the back. It was on my job list to re-flash with the later updates, but I'm a procrastinator, and today the thing gave out. When I turn it on I get an obviously backlit display and a red light. It doesn't get as far as the 'Custom Firmware...' display. Does nothing after that, and doesn't respond to the remote or the panel keys.
    After the horse has bolted I tried re-flashing. If I turn off the machine at the back and turn it on whilst pressing the power button on the front, it looks like it does something, counting P numbers from 0 to 100 a few times round and then shows 'END'. It doesn't reboot itself though, no matter how long left alone, and a hard reset using the switch on the back does nothing other than take me straight back to blank and red.
    Is it toast? Or is there a way back from here?
  2. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,991
    Perchede 32460
    +456
    Try disconnecting the hard drive and see if it boots then.
    • Like Like x 1
    • Agree Agree x 1
    • List
  3. Railway
    Railway
    Nov 29, 2009
    721
    43
    +105
    Doubt it's anything to do with custom F/W.
  4. Ayrton
    Ayrton
    Dec 4, 2002
    649
    Leicestershire
    +21
    Thanks REPASSAC, you're on the money, it boots without the HD.
    @Railway, I didn't think for a minute it was. I've been running it for ages. I figured the box had given out, whilst hoping it was just the hard drive had got itself in a tangle. It appears to be the latter, as I have it plugged into this machine now which identifies it. I'm hoping if I clear it down and put it back I will be good to go.
  5. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,627
    Redditch
    +4,208
    You may resolve the issue by simply renaming the 0.ts timeshift file to force the box to create a new one on a different area of the hard disk. If so probably time to copy the video partition to a PC and fitting a new drive.
  6. Ayrton
    Ayrton
    Dec 4, 2002
    649
    Leicestershire
    +21
    I put a spare HD in it last night, any old one I had lying around, and it works perfectly. My understanding is that this is not acceptable in the longer term, and that I need the right spec drive? What will happen to the box/HD if they are left as they are?
    It is not necessarily my intention to leave them that way, and if I can sort the old drive out I will put it back. But it would be useful to know what the potential consequences of inaction are. We're getting decent broadband in the next few weeks I believe. If this is so I will probably switch to a YouView or Freetime box, so I don't want to spend any money on the old Foxsat.
  7. TJT1
    TJT1
    Jul 29, 2011
    4,833
    East Sussex, UK
    +1,141
    Did you try what was suggested in post#5. You will then have the right disc in itm not 'any old disc'. If it's a disc fault, which it sounds like, there are other checks that you can do.
  8. Ayrton
    Ayrton
    Dec 4, 2002
    649
    Leicestershire
    +21
    I will do that, but I was having unrelated problems with both my PCs last night and I wasn't able to get as far as reading the disk. I put something else in to keep the kids quiet whilst I complete my investigations.
  9. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,627
    Redditch
    +4,208
    As the drive gets older the built in error checks in PC drives will make it unreliable. You need a AV specced drive.
  10. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,991
    Perchede 32460
    +456
    Wisdom indeed :lesson:
    Graham & I both find the WD AV drives very good - you will need a jumper across two pins to slow the current range down.
