My trusty Foxsat-HDR (with the superb Custom Firmware 4.1.3 installed) has developed its first fault:
The "Power ON" feature has ceased to work for its morning startup.
When I turn the machine on it is evident that the "Power On Channel" has not been selected.
However if I then select startup times for say 10 minutes ahead, or one hour ahead, turn the machine off I find the system behaves as it should.
Any ideas as to why this fault may have occurred?
Is there anything I could try before doing a Factory Reset?
Thanks in advance
Thanks in advance
