Foxsat HDR 'on time' recording
SimonGunning
Hello,
I just had a Foxsat HDR installed as part of the iPlayer private beta and cannot find the 'on time' recording feature.
I'm pretty sure it should be an option in the recording start and end time menu but it's not there.
Am I being REALLY DUMB?
Thanks all,
Simon
grahamlthompson
In memoriam
Not sure what you mean but presume you mean accurate recording. It's enabled by default and to turn it off you have to goto Menu/settings/recording and set start and end time to other than auto
SimonGunning
Thanks - the user guide refers to it as 'on time' recording and there's a screen grab of the menu with 'on time' as an option.
I'll take your advice and assume it's on.
Thanks,
Simon
grahamlthompson
In memoriam
Thanks,
Simon
It's a screw up in the manual, the menu actually says auto. On time is used in the Humax Freeview+ boxes.
