Foxsat HDR File Manger
wiggers
I find the File Manager completely useless.
I'm trying to copy several editions of Wallander from a folder containing 20-odd episodes to an external USB drive.
1. How do you find out which episode is which?
2. Having copied a few across, how do you know which ones have been copied and which haven't?
3. Having copied a file, the highlighter goes back to \.. - very helpful! It doesn't mark the last file copied!
4. Has anyone come across a more useless file manager?
logiciel
Presumably you're meant to rename them as you record them.
Isn't that possible under Edit and isn't the date shown anywhere?
grahamlthompson
In memoriam
I know where you are coming from but you have missed a trick. You don't have to copy one at a time. Having opened the right folder for the destination go back to the left pane and enter the folder for the files you want to copy. Press yellow and then OK on all the files you want to copy, then green to copy all of them at once.
wiggers
Maybe, I haven't tried, but you shouldn't need to do that. Why does File Manager strip away every peice of information that might help you differentiate the recordings?
wiggers
I tried that but it said there wasn't enough space. I have an 80GB drive, but because the Humax doesn't understand NTFS I had to partition it into two 32GB FAT32 and a third, smaller, partition. So the sum of the recordings was too much for one partition. Back to square one.
grahamlthompson
In memoriam
So just select half of them or use the EXT3 file system
wiggers
Well, the error message I got when I tried selecting all and copying was rather obscure and led me to believe I was doing something wrong. (I forget the actual wording.) So I gave up on the multiple copy and did them individually. It was only when I got the same error message when copying the 15th or 16th file I realised what it meant.
The transcoding software is on Windows, which doesn't understand ext3.
ADAMFOULKES
Hey,
There is a free EXT 3 reader for windows that will loow you to play back the files in Windows Media Player. Just google it! :0):clap:
logiciel
The more I discover about Freesat receivers the more glad I am that I don't have one.
grahamlthompson
In memoriam
I thought you liked a challenge :D. Don't knock it till you try one :D
logiciel
Ok, I know I'm being a bit of a dog in the Manger;) about this one.
