Many thanks for this. Do i downoad this to my laptop or the foxsat hdr?
I would prefer to have a wired solution, is this possible ?
Thanks for the reply. Is it not possible to wire the lap to the tv or foxsat All I want to do is play films from the laptop hd on the tv. I dont want to access the internet.
But I dont want to set up an network, I dont want to connect to the internet. All I want to do is play films which are on my laptop
Unless the laptop has HDMI or VGA out then without networking the TV and the laptop there's no other way other than burning content to DVD and playing these back on the TV. You could try setting up a peer to peer network between the laptop and the TV.
Windows Peer-to-Peer Networking
Much easier to connect the TV and Laptop to your router
Presumably you have a router as you are posting here, frankly I don't see the problem.
What happened to your original request Foxsat-HDR, can I connect my laptop to it ?
Would it work if i connected the laptop to the foxsat vias usb ?
Thanks for the replies. Both the laptop and tv have vga connectors so a cable connection there will give me a picture. How do I get sound ?
Thanks. I have done this and I get a picture which is the same as the screen on my laptop. How do I make the picture on the tv fill the screen as it does on the laptop
I looked at the control centre and my laptop only has resolution of 1024 x 768 or 1152 x 864 or 800 x 600.
