Bargain Expired Fox direct UHD discs at £16!
Discussion in '4K Ultra HD Blu-rays' started by Essoman, May 3, 2016.
  1. Essoman
    Essoman
    Feb 8, 2010
    1,179
    116
    Beccles
    +591
    Rakuten.co.uk Shopping: Ultra HD blu Ray
    Rakuten (used to be play.com) offer on all fox direct UHD blus £20 and 400 points which is £4 to spend on the site, offer throughout May. Makes the discs £16. Just ordered Hitman.
  2. BrynTeg
    BrynTeg
    Sep 9, 2000
    15,183
    167
    Cardigan Wales
    +2,003
    How do you get the 400 points to apply to your order? don't you have to order first for the points to be applied?
  3. Essoman
    Essoman
    Feb 8, 2010
    1,179
    116
    Beccles
    +591
    Yes points for later orders.
  4. Blupetros
    Blupetros
    Mar 26, 2013
    793
    4
    Garden of England
    +437
    Be careful though, "The Super Points earned during the Promotional Period will only be valid until 30th June 2016 and after this date they can no longer be redeemed". I made the mistake once and lost a few £'s of points!:(
