Four LNBs signals differ
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Silver salmon, Aug 28, 2013.
  1. Silver salmon
    Silver salmon
    Aug 28, 2013
    5
    I am new here so please if I don't explain do ask questions.
    My problem is I have a four LNBS and watching the signal strength meter tuner one is showing Strength good - Quality normal but the other tuner two is showing Strength Good and Quality bad. Why would there be such a difference between the two when they are connected on the same dish?
    T
  2. ant_thomas
    ant_thomas
    May 14, 2007
    321
    28
    +34
    Is this a quad LNB? Or 4 separate LNBs?
  3. Silver salmon
    Silver salmon
    Aug 28, 2013
    5
    It's a quad LNB and a Humax tuner
  4. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    Could be faulty LNB, faulty cabling/connections or faulty tuner.
  5. Silver salmon
    Silver salmon
    Aug 28, 2013
    5
    The LNB is only six months old and so is the tuner. Is that the only thing that could be wrong?
  6. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    Just because they are new doesn't mean they aren't faulty....
    First thing to do would be to swap the cables at the receiver end to see if the low signal moves from tuner 2 to 1...
  7. Silver salmon
    Silver salmon
    Aug 28, 2013
    5
    Thanks for your help will try swopping them when I get chance can't now because of the boss and soaps.
    Ta
  8. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Swapping cables at receiver will show whether receiver or lnb/cabling is faulty - if it stays on same input then receiver is faulty, if it swaps input then lnb or cabling is faulty and if fault disappears you had a faulty connection. The second test would be to swap cables at the lnb - this will show whether cabling or lnb is faulty - if it swaps cables then lnb is faulty and if stays with same cable then cabling/connections are faulty and again if fault disappears you had a faulty connection.
  9. Silver salmon
    Silver salmon
    Aug 28, 2013
    5
    thanks for your advice will look into it.
  10. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,650
    Cheshire
    +1,079
    just as a reference - a lot of sky boxes have different readings on their inbuilt meters on the two tuners from the same quad lnb - usually tuner a is higher & tuner b is the lower - if you swap the cables it's usually the same result - tuner a is still higher & tuner b is lower & when you put a pro meter on all the lnb outputs they are pretty much all the same.
  11. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,759
    Exactly.
    With digital you get either all or nothing - the numbers don't really matter.
  12. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    Only they do... if you know a receiver has a breakup threshold of 30% and your viewing a strong sat at 35% during fine weather you have issues!
  13. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,759
    Very true.:smashin:
  14. ant_thomas
    ant_thomas
    May 14, 2007
    321
    28
    +34
    I noticed similar the other week when I changed the Quad on our Sky dish to an Octo. I was surprised at the size of the difference on the Sky box readings, not that it gives any numbers, just the coloured bar.
    The Octo is definitely peforming better on my other equipment, or I aligned it better than the Sky man aligned the Quad years ago.
  15. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,759
    How better?
  16. ant_thomas
    ant_thomas
    May 14, 2007
    321
    28
    +34
    Higher SNR/signal quality than on the old quad.
    Can't remember exactly which transponders but some are coming in >16dB whereas I don't think I ever saw anything over 14.5dB previously.
  17. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,759
    But are you getting more channels than before, consistently?
  18. ant_thomas
    ant_thomas
    May 14, 2007
    321
    28
    +34
    Hopefully you're not confusing the threads!
    This is an Octo LNB on a static Sky dish on 28.2E. Still getting all the 28.2E channels.
    I was merely making an observation that after changing the original Quad for an Octo LNB the SNR/quality had increased.
  19. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,759
    Your hopes are justified!
    I'll just say that it won't make any difference then to you, except maybe in extreme weather conditions.
