Forza Motorsport
Discussion in 'Nintendo Forums' started by evolution400, May 24, 2005.
  1. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Hi guys just bought the PAL version of this game and am wondering does anyone know what resolutions the PAL and NTSC versions they support ?
    Are they the same ?
    Or is there a list of newer games and res they support ?
    I cant seem to alter the car setup either only the tyres I can alter is there a trick to this ?
    thanks guys.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,131
    Canterbury, Kent
    +732
    Both versions run at 480p, nothing higher
    In car setup press the right trigger to change what part of the car you want to adjust. but before you do this you need to of purchased the professional part Eg if you want to adjust the gearing you need to have the most expensive gearing installed on your car.
  3. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Thanks a lot mate I will give that a try when I get in tonight :)
    You dont happen to know the res on starwars episode 3 also ?
  4. Pooon
    Pooon
    Dec 26, 2002
    7,131
    Canterbury, Kent
    +732
    It does not specifiy on the back of the box for $tar War$ what the res is so it will probably be 480p as well, 95% of xbox games are only 480p
    If you have Forza why would you want Episode 3 anyway?!?!?!?!?
