Forward firing and down firing
Discussion in 'Subwoofers' started by iaria, Nov 13, 2004.
  1. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Hi I have noted that now Bk has an XLS down firing, very nice indeed
    now what my question is is there any difference in bass between the two?
    They have both the same power and construction quality
    Gerry
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    There should be no difference in the quality or amount of bass between a front and downfirer per se. What differences there are will be down to overall design and construction plus the type and quality of components rather than which direction the driver faces.
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    Aldershot, Hampshire
    +265
    Would placement and room acoustics play some part in the performance of each? If you placed each sub in the exactly the same environment would you expect to get a similar sound given the components and construction are of similar quality? With it being lfe only is it less directional than conventional speakers then. I have never really understood what the pro's and cons of each are and why manufacturers offer both down firing and side firing models :confused:
  4. recruit
    recruit
    I have heard and must say cannot confirm if it is true but people with wooden floors prefer front fireing subs rather than downward.
    John
  5. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I believe that each model of sub will react differently in the same room setting irresepective of whether it is front or down firing due to other parameters in the design such as position and size of port.
    An example would be the SVS range which includes both cylinder and box subs and utilize the same drivers and amps in each. The traditional box shaped subs are downward firing but rear ported so will perform better placed further away from the walls than the cylindrical shaped subs which has ports facing upwards.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    That's pretty much it, the driver orientation is just another aspect of how it loads the room. As has been mentioned, room construction can play a major part (eg. suspended floor or concrete foundations etc).
    Although a different driver orientation probably will change the frequency response in a given room, it's unlikely to change the quality or "amount" of bass that's generated by it.
  7. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Thank you again for the replys, I suppose it would have something to do with looks, if you want to see a grill then get forward firing if not down firing
    BTW I have laminated floor
    Gerry
  8. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    I'm having my front facing XLS200 changed to a downwards facing version. It was back in for repair due because it'd started to hum :oops: Lets hope the DF is just as good as the forward facing version :D
    I'll let you what its like as soon as it arrives back. Tom if you're reading this HURRY UP!
  9. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Thank you coastersteve it would be nice to know if you notice any difference in DF and FD
    Gerry
  10. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Just to confuse you further it won't be that relevant whether coastersteve hears a difference or not as subs will interact with each different room in a different manner.
  11. Jules
    Jules
    Oct 11, 2000
    5,076
    +754
    I used to suspect that forward firing subs would work better on suspended wooden floors. But since replacing my 2 KEF45B subs (forward firing) with an SVS PC Ultra (down firing) I've been convinced otherwise.
    My cinema is in an attic and has a suspended wooden floor.
    I was worried at first when I ordered the PC Ultra, but I took a chance.... and it paid off, big time! It works brilliantly.
    As others have said, there are many influencing factors that determine how one particular sub will work in your room. Down or forward firing is just one of these factors, and you'd do better to focus your attention more on the overall quality and performance of the sub.
  12. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    Any update on this lads....?
    http://www.bkelec.com/new/Special_Offers/sp10.htm
    I'm seriously considering BK... and not sure of downward of forward firing version.
    I will have laminate floor, and the sub will be placed near the rear wall, next to the side of my sofa.
  13. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    Mine should be with me today according to BKelec :thumbsup: I'll let you know what the neighbours think of it later tonight :oops:
  14. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    Tom @ BK says its makes no real difference.
    If you've got no loose floorboards, then it doesn't matter....
    he would PREFER the downward one himself, if he HAD to choose!
    and that is PURELY on aesthetics.
    Look forward to your review CoasterSteve!
  15. Stone Free
    Stone Free
    Jun 13, 2001
    868
    28
    London
    +28
    If you have carpets, should you avoid downward firing?
  16. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I have had a couple of downfiring REL Storms that fired into the carpet and I had no problems at all with them.
  17. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    Ok, its setup and working!! VERY quick review.
    The downward facing is definatly more wife friendly. I had the original black XLS and the missus was not 100% keen on it but put up with it :) but this she loves cos it matches everything else.
    Sound
    At first the DF sounded a little more "boomy" if that makes sense, didn't seem as musical as the FF but turning down the gain integrated a lot better. Its still early days to say which is better as I've yet to watch a film on it.
    I'll report more findings later when I've watched a film
  18. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Great stuff coastersteve, I am stll waiting to order one and this will help
    Gerry
  19. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    Just given it some abuse with Independance Day -------- WOW :clap: :thumbsup:
  20. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    So its a winner ... though is it better than the FF?
    Did you get black again or one of the other colours?
    I will be getting the DF one... when I get round to getting an AMP and DVD player!!
    (just looked at my finances!! :eek: .)
  21. coastersteve
    coastersteve
    Jan 7, 2003
    64
    +3
    I went from a Black Forward Facing to an Oak Downward facing. At the time BK didn't do ash in the FF version.
    The misses definatly likes the Oak one better - A RESULT!!! :D
  22. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Sounds good, any sound differences are almost certainly down to the finish on the sub. Black ones go fasta :D
    [thinking mode]Ponders if adding go-fasta stripes to his sub would improve performance...[/thinking mode]
